Deelee91
Error 1606 (Java), does not give me a location
Wed Jan 19, 2011 11:05 pm
I am trying to install Java and I get this Error (Error1606.Could not access network location .: )
as you see, all i get for the location is a Dot and a Semi Colon.
he is the part of the Crash Log
value: 'C:\Documents and Settings\All Users\'.
MSI (s) (6C:90) [21:53:21:192]: PROPERTY CHANGE: Adding JAVA property. Its value is 'C:\Program Files\Java\'.
MSI (s) (6C:90) [21:53:21:192]: Note: 1: 1314 2: :
MSI (s) (6C:90) [21:53:21:192]: Note: 1: 1606 2: :
MSI (c) (98:AC) [21:53:21:192]: Transforming table Binary.
Error 1606.Could not access network location :.
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 224 could not be cancelled. Error: 127
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 2932 could not be cancelled. Error: 127
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 2936 could not be cancelled. Error: 127
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 972 could not be cancelled. Error: 127
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 1412 could not be cancelled. Error: 127
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 3388 could not be cancelled. Error: 127
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 2552 could not be cancelled. Error: 127
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 924 could not be cancelled. Error: 127
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 2368 could not be cancelled. Error: 127
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 272 could not be cancelled. Error: 127
MSI (s) (6C:28) [21:53:24:973]: I/O on thread 3984 could not be cancelled. Error: 127
MSI (s) (6C:90) [21:53:24:973]: Product: Java(TM) 6 Update 22 -- Error 1606.Could not access network location :.
MSI (s) (6C:90) [21:53:24:973]: Note: 1: 1606 2: :
MSI (c) (98:AC) [21:53:24:973]: Transforming table Binary.
MSI (c) (98:AC) [21:53:24:989]: Transforming table Binary.
MSI (s) (6C:90) [21:53:25:661]: Product: Java(TM) 6 Update 22 -- Error 1606.Could not access network location :.
Action ended 21:53:25: CostFinalize. Return value 3.
Action ended 21:53:25: INSTALL. Return value 3.
Property(N): DiskPrompt = [1]
Property(N): Registration = No
Property(N): UpgradeCode = {57BDA5C6-443C-4D65-B233-2823932160FF}
Property(N): RemoteAdminTS = 1
Property(N): VersionNT = 501
Property(N): REMOVE = ALL
Property(N): TARGETDIR = H:\
Property(N): ALLUSERSPROFILE = C:\Documents and Settings\All Users\
Property(N): AdminToolsFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools\
Property(N): AppDataFolder = C:\Documents and Settings\deelee\Application Data\
Property(N): CommonAppDataFolder = C:\Documents and Settings\All Users\Application Data\
Property(N): CommonFiles64Folder = H:\
Property(N): CommonFilesFolder = C:\Program Files\Common Files\
Property(N): GlobalAssemblyCache = H:\
Property(N): JAVA = C:\Program Files\Java\
Property(N): INSTALLDIR = :
Property(N): ProgramFilesFolder = C:\Program Files\
Property(N): LocalAppDataFolder = C:\Documents and Settings\deelee\Local Settings\Application Data\
Property(N): ProgramFiles64Folder = H:\
Property(N): System16Folder = C:\WINDOWS\system\
Property(N): System64Folder = H:\
Property(N): SystemFolder = C:\WINDOWS\system32\
Property(N): TempFolder = C:\DOCUME~1\deelee\LOCALS~1\Temp\
Property(N): TemplateFolder = C:\Documents and Settings\All Users\Templates\
Property(N): USERPROFILE = C:\Documents and Settings\deelee\
Property(N): WindowsFolder = C:\WINDOWS\
Property(N): bin = :
Property(N): WindowsVolume = C:\
Property(N): MsiNTProductType = 1
Property(N): ServicePackLevelMinor = 0
Property(N): ServicePackLevel = 3
Property(N): WindowsBuild = 2600
Property(N): VersionMsi = 4.05
Property(N): VersionDatabase = 200
Property(N): CLIENTUILEVEL = 0
Millions of People on the internet are receiving this strange error,and i guess this forum would be the best help, as it seems you lot are the expert with windows installer
mihai.petcu
Re: Error 1606 (Java), does not give me a location
Thu Jan 20, 2011 2:57 pm
Hello and welcome to the Advanced Installer Forums,
Since this is a JAVA installer package issue you should contact the JAVA support team regarding this issue.
However, there seems to be a problem with the previous version uninstallation. It seems that somehow some folders have invalid values in the upgrade process(":"). You could try to manually uninstall the old version and then install the new version.
Deelee91
Thu Jan 20, 2011 3:30 pm
I have never Previously install Java, this a completely new install of it.
I tried to contact Java, but all they have is liveperson. "www.liveperson.com" http://www.liveperson.com/lp/java-help/?BanID=22489 which is absolutely useless, the tech people have no idea what i am saying.
I tried to fix it using this website http://support.microsoft.com/kb/886549, but all these registry items are ok.
Value name Type Value data
Common AppData REG_EXPAND_SZ %ALLUSERSPROFILE%\Application Data OK
Common Desktop REG_EXPAND_SZ %ALLUSERSPROFILE%\Desktop OK
Common Documents REG_EXPAND_SZ %ALLUSERSPROFILE%\Documents OK
Common Favorites REG_EXPAND_SZ %ALLUSERSPROFILE%\Favorites OK
Common Programs REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs Ok
Common Start Menu REG_EXPAND_SZ %ALLUSERSPROFILE%\Start menu OK
Common Startup REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs\Startup OK
Common templates REG_EXPAND_SZ %ALLUSERSPROFILE%\Templates OK
but the MSI errors give me an unknown location, could an Orca Editor fix this?
