davidesharpe
Changing IIS Authentication, depending on a property
We have a project that installs a .net web application in IIS, we have an option in the installer to choose to use Active Directory security or not.
My issue is that we'd like change the 'allow anonymous web access' of the application, depenant on if the user chose active directory or not.
Also we'd liike to change some of the custom errors, but again ONLY if they chose Active Directory
How can I achieve this ?
Also is there a way to change the authentication on a single file in the web application ?
mihai.petcu
Re: Changing IIS Authentication, depending on a property
Unfortunately there is no way to condition that setting. You can however try the following approach to condition settings for a web application:
  • create a public property in the Install Parameters page that resolves to the web application's installation name
  • add a new web application in the IIS page with the same formatted reference to the public property
  • modify each according to the different scenarios you need
  • condition each of them accordingly( Active Directory setting in your current case )
This way only one web application will be conditionally installed.
You can try using file permissions in the Files and Folders page to accomplish this.
davidesharpe
If I understand you correctly you are saying.
1. Create two (almost identical) websites in the IIS page. One with active directory settings one without.
2. Have a property that is indicates Active Directory or not. (We already have a WT_MEMBERSHIP property that is set to 'StandardLogin' or 'ActiveDirectoryLogin')
3. In the Install Condition of the two websites, one will have WT_MEMBERSHIP='StandardLogin' and the Other will have "WT_MEMBERSHIP='ActiveDirectoryLogin'
and therefore only one or the other of these two sites will be created.
mihai.petcu
Yes, this is what I meant by suggesting the settings above.
davidesharpe
Thanks, that worked
