I am new and evaluating Advanced Installer 1.8.
I am trying to set up a new professional project that should be very simple. I simply need to copy a Microsoft Access database file, create a shortcut and create a system ODBC data source to connect to a SQL server.
I can figure everything out except creating the system ODBC data source. I am used to doing it manually by specifying a name, server, username/password and database.
How do I set this up with Advanced Installer? I try to add a new ODBC datasource, but I don't see where to add all of the information. I looked up the info on the same ODBC datasource using regedt32, but it doesn't specify things like the password in the data fields.
Thanks!
