meetshashank
Advanced Installer Hangs
I Have AI 9.3 solution which works perfect in 9.3
But when i migrate it to next version it hangs when we run out put installer or (When run and log)
Now i can not even test / run any Installer version on my machine it gives below ...It wont show any further steps
But surprise it works on mahcine where AI is not installed...I want new installer to create on my machine and test ..... but i can not due to above problem
This is event Log Information Logged ....
The description for Event ID ( 11708 ) in Source ( MsiInstaller ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: Product: SMEPAYROLL UPDATE - AU092012 -- Installation failed., (NULL), (NULL), (NULL), (NULL), , .
The description for Event ID ( 1033 ) in Source ( MsiInstaller ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: SMEPAYROLL UPDATE - AU092012, 2.1.0, 1033, 1602, (NULL), ,
[/i][/b]
Cosmin
Re: Advanced Installer Hangs
Can you please send us the .AIP (project) file you are using to support at advancedinstaller dot com so we can investigate it?
Cosmin
meetshashank
Here U go with AI project Installer file..
Many Thanks
Shashank
SupportingFiles.zip
(2.07 KiB) Downloaded 351 times
AU092012.back.aip
(23.48 KiB) Downloaded 410 times
AU092012.aip
(28.81 KiB) Downloaded 407 times
mihai.petcu
The same issue is debated in the following thread:
http://www.advancedinstaller.com/forums ... 310#p54167
MIhai
