I am having trouble stopping and starting the print spooler service during the install package.
When I run the package I get the following error:
Product: printer OCE 2090 PS - CENTER v3.2 -- Error 1920. Service 'Print Spooler' (Print Spooler) failed to start. Verify that you have sufficient privileges to start system services.
In the Installer package I am doing the following:
o Setting the registry settings to create the printer ports
o I usa a Control Operation with Stop Checked in Event on Install
Service Name is set to Print Spooler
Attached Component is set to the first Registry Entry
o I then use another Control Operation with Start Checked in Event on Install
Attached Component is set to the last Registry Entry
o Lastly I have a Custom Action in the Commit with no impersonation to install the printer drivers and printer.
(I also tried this with impersonation - no difference, still can't stop and start the services.)
All works except the start and stop of the service... so the printer driver will fail install on some PC's because it will not yet see the port I created with the registry entires.
Any help would be appreciated.
Rick
