I've tested the scenario and indeed I was able to replicate the behavior. This error seems to be generated by the default permissions which are added by default at install time to temporary files. As a workaround you can add your "AU_complete.txt" file as a regular file and add
Everyone-> Full Control permissions on it. So, can you proceed like this:
1. remove the "AU_complete.txt" temporary file added in "Files and Folders" page
2. add the "AU_complete.txt" as a regular file in "Windows Volume\Temporary" folder from "Files and Folders" page
3. select the added "AU_complete.txt" file, from its context menu choose "Properties..." option and go to "Permissions" tab
4. add
Everyone -> Full Control permissions on the "AU_complete.txt" file
5. go to "SQL Script Replacements" tab and edit your script replacement like this:
- Find what: your file path
Replace with: [TempFolder]AU_complete.txt
6. rebuild and test again the setup
and see if this helps?
