I'm new to this, so bear with me. I have associated file extensions with my application, and provided icons. However, after install on a target machine the icons do NOT appear in browsers.
Is there some trick I'm missing?
We will add these improvements in a future version of Advanced Installer. Thank you for your suggestions.It might be nice for wizards to check whether a leading dot had been used and take appropriate action. Even simpler would be to specify in the help file that no leading dot should be used.
