adkerremans1
Ask for service name
I want to be able to install my program mutiple times and need to be able to manually enter a service name?
Is that possible?
Regards
Ad
Re: Ask for service name
Hello Ad,
This should be possible by enabling the "Allow side by side installation of different Product Versions" option from the "Upgrades" page.
For this, you can proceed as it follows:
- create a new dialog in "Dialogs" page
- add an "Edit Box" control to it
- set the property of that edit box to, for instance, MY_SERVICE_NAME
- go to "Services" page and in the "Service Name" field, input the property above, e.g.:
[MY_SERVICE_NAME]
adkerremans1
Hello Catalin,
Is it true that I need the "Enterprise" Edition to be able to add the type of dialog that you descritebed?
Regards
Ad
Hello Ad,
Yes, in order to use the "Dialog Editor" feature, the Enterprise suite is required.
