Hi
I bought advanced installer 2 days ago, followed every video and guide I can find. My setup is quite simple but when it gets to this task:
- task: AdvancedInstaller@2
displayName: 'Build Advanced Installer package Digital Signature.aip'
inputs:
advinstLicense: '$(advancedinstaller.license)'
aipExtraCommands: 'SetDigitalCertificateFile -file $(leadhootzCertificate.secureFilePath)'
aipPath: '$(Build.ArtifactStagingDirectory)\installer\LinkedInAutomation.aip'
aipBuild: 'DefaultBuild'
It times out (after about 60 minutes). Should it really take this long? But I don't get any meaningful error message so I don't know what to do next.
Starting: Build Advanced Installer package Digital Signature.aip
Task : Advanced Installer Build
Description : Build setup packages using Advanced Installer.
Version : 2.0.7
Author : Caphyon
Help :
Downloading: https://www.advancedinstaller.com/downloads/updates.ini
Checking if a cached copy exists for this version...
Cache does not contains this Advanced Installer version. Will be downloaded and installed.
Downloading Advanced Installer. URL: https://www.advancedinstaller.com/downl ... dvinst.msi
Downloading: https://www.advancedinstaller.com/downl ... dvinst.msi
Extracting Advanced Installer
"C:\Windows\system32\msiexec.exe" /a "D:\a\_temp\45e51da0-3a84-4216-a402-7db0ef2d0e78" TARGETDIR="D:\a\_temp\AdvancedInstaller\resources" /qn /l*v "D:\a\_temp\AdvancedInstaller\advinst_install.log"
Caching Advanced Installer tool.
Caching tool: advinst 19.3.0 x86
Successfully cached Advanced Installer tool. Version 19.3
Registering Advanced Installer.
C:\hostedtoolcache\windows\advinst\19.3.0\x86\bin\x86\AdvancedInstaller.com /RegisterCI ***
Prepending PATH environment variable with directory: C:\hostedtoolcache\windows\advinst\19.3.0\x86\bin\x86
C:\hostedtoolcache\windows\advinst\19.3.0\x86\bin\x86\AdvancedInstaller.com /execute D:\a\1\a\installer\LinkedInAutomation.aip D:\a\_temp\17839.aic
##[error]The operation was canceled.
Finishing: Build Advanced Installer package Digital Signature.aip
