Mel
How can i install the build after compilation ?
Fri May 14, 2021 5:07 am
Hi ,
I have a Advanced installer build script that outputs an exe file.
Is there a way I can run the exe an accept the default values (ie without having to click on Next -> Next etc) ?
I have tried the following from command line
c:\myproject\sampleproject.exe /S
but it gives the error , "Invalid Command Line"
Re: How can i install the build after compilation ?
Fri May 14, 2021 1:02 pm
If you want to install the setup silently, you can use a command line as it follows:
setup.exe /exenoui /qn
