I use Roaming Desktop.
This error occurs during update:
Unable to write to the specified folder:
\\remote_server\user\some_folder\Desktop\.
Can you help to solve this issue?
Its possible to skip write shortcut (or use local Desktop folder)?
Yes, it is possible to skip the creation of the shortcuts.Its possible to skip write shortcut (or use local Desktop folder)?
Unfortunately, we do not have predefined support for that.Can you explain how to check that folder exists?
I found Desktop folder variable, but I can't find function to check the folder exists.
\\remoteServer\Users\<username>\Desktop
