ChrisGue
Problem "user account already exists"
I use AI 14.1.1 enterprise
On updates the installation faiIs with user account already exists on some computers.
I have a log file attached.
How to fix this?
Thank you,
Chris
MSI84fd4.LOG
(786.66 KiB) Downloaded 277 times
Re: Problem "user account already exists"
Hello Chris,
Thank you for providing the log file.
After investigating it, it looks like the issue is not related with the fact that the user may already exist on some machines.
MSI (c) (10:68) [08:55:59:472]: PROPERTY CHANGE: Adding FileInUseProcess property. Its value is 'The following applications should be closed before continuing the install:{&^&}5988{&^&}PureSync, a file and folder synchronization and backup tool, by Jumping Bytes{&^&}{&^&}{&^&}{&^&}{&^&}{&^&}'.
It looks like a file that the setup tries to update is kept in use, therefore the update can not be completed.
MSI (c) (10:AC) [08:56:13:387]: PROPERTY CHANGE: Modifying AppsShutdownOption property. Its current value is 'All'. Its new value: 'None'.
It also looks that the user has chosen to not close the applicaiton in the "FileInUseDialog".
ChrisGue
PureSync is the program being updated by my installation.
And usually this works fine when PureSync.exe is still running while the (update)-installation is started.
The dialog 'file in use' is shown, an the installation continues regardless which option the users selects without error.
I could never reproduce that error myself.
So there must be a problem on these computers on which this error occurs.
So any idea how to solve this?
Chris
Hello Chris,
Perhaps it is not the .EXE itself that is causing the issue, but some other file that is kept in use by the .EXE.
An example would be this - your .EXE is running and at the moment when the upgrade happens it tries to write to a .TXT file that is scheduled for upgrade. In this scenario, the "File in use" dialog will pop-up.
The recommended approach in this case is explained in the "How to detect or stop a process" article.
ChrisGue
but why should a running exe cause the error :
I do not understand how this might be connected
As far s I understand this is something else, but what
It seems the the installation wants to add an user? Why?
thanks, Chris
Hello Chris,
This is strange, indeed.
Unfortunately, I can not really say why this is happening.
In order for me to further investigate this, could you please forward me the following resources:
  • a copy of the old AIP file
  • a copy of the new AIP file
  • a download link for the older setup
  • a download link for the newer setup
  • perhaps a test case, if required
by e-mail at support at advancedinstaller dot com?
