jsmith99
Ability Specify custom folder for dynamically created powershell files
Thu Apr 29, 2021 11:31 pm
When scripting out custom actions, Advanced installer will automatically create powershell scripts used to launch actions in the temp directory (c:\windows\temp) with filenames like: pss1214.ps1
We would like to be able to specify _where_ these files are created so we can whitelist them with our AV software.
Thanks!
Re: Ability Specify custom folder for dynamically created powershell files
Tue May 04, 2021 5:03 pm
This improvement is already on our TODO list of improvements.
I will update this thread as soon as this will be added to Advanced Installer.
Return to “Feature Requests”
