PhilippeG
refresh current Quick Selection Tree
Mon May 03, 2021 1:19 pm
In a dialog, in publish events, after
an "install one or more feature locally" event,
and a "refresh dialog" event
the Quick selection tree control is not updated
Is there any custom action to force it?
Regards
Re: refresh current Quick Selection Tree
Wed May 05, 2021 7:36 pm
Hello Philippe,
I have tested this and everything worked as expected.
Please see the attached sample project:
Philippe Sample.aip
(18.88KiB)Downloaded 223 times
Please note that the "Quick Selection Tree" control requires the "Enhanced User Interface" option to be enabled. Could you please double check if this is enabled, i.e. "Themes" page --> "Settings" tab.
PhilippeG
Thu May 06, 2021 8:26 am
But that doesn't work with the QuickSelectionTree
What is the AIEXTERNALUI?
Regards
Mon May 10, 2021 2:24 pm
Hello Philippe,
For some reason, I thought you were refering to the "Quck Selection List" control.
I have tested this just now and it looks like the "Quick Selection Tree" control is not updated properly. Unfortunately I can not say for sure why this is happening.
I have forwarded this to our development team and hopefully this will be fixed in a future version of Advanced Installer.
In the meantime, you could use the "Quick Selection List" control, which is very similar to the tree control.
Thu May 27, 2021 2:52 pm
Hello Philippe,
This has been fixed in version 18.3 of Advanced Installer, released on May 24th, 2021.
