Re: Task Scheduler for Updates
We apologize for any inconveniences. The high load of support tickets requires us to equally split our time and answer all of our users (all commercial licenses include the same type of support, thus all customers are treated equally). In such situations reply times are usually in the 24h timeframe (we try to answer faster than the 48h limit mentioned in our EULA), except week-ends.
Regarding your problem, please make sure that the scheduled task is configured correctly (no username and password) in both the older and newer versions of your projects and also that the installed detection of the updates is set correctly in your "Update Configurations" project.
markcvrs
Hi Eusebiu,
Thank you for clarifying this, I appreciate that now I know. Well I have done exactly what you said and the job never runs the error I get form scheduler is to do with access denied. So basically the account doesn't have permissions to start the task? Because if i set the author of the task to myself it works as expected.
Can you reproduce the problem on multiple clean machines? If so, can you please send me, to support at advancedinstaller dot com, a link to download your packages or some sample packages that reproduce the behavior, so I can test them and try to find the problem.
themuffinman
I'm also experiencing this issue. I set my package to per user only, no admin privileges and now it happens.
I have answered your other forum thread here:
Access denied creating updater scheduled task
