twdotson
Please discontinue the use of version in AdvIns installed path
Every time a minor release installs, it breaks ALL of our batch files that we rely on to automate builds!
Like most other software, simply install to:
"C:\Program Files (x86)\Caphyon\Advanced Installer"
Re: Please discontinue the use of version in AdvIns installed path
The use of versioned folders is especially helpful for customers who install the versions side by side.
If we do not use the version in the installation path, that scenario becomes completely unusable.
I would suggest using a variable for the version and then changing only the variable so the path is always up to date.
twdotson
Thanks, that will work, at least I only need to change it in one location when a new version installs.
You're always welcome!
This improvement has been added in version 22.0 of Advanced Installer, released on August 21st, 2024.
Return to “Feature Requests”
