Zsolt Kollarits
Custom ProductCode GUID based on build type
Dear Advanced Isntaller,
Is it possible to set a custom ProductCode GUID for our product based on the build type?
We have right now 4 builds (screenshot attached).
For the "_online" builds we would like to have a GUID, but it's important, that if we generate a non "_online" build, that should have a different ProductCode GUID.
Our idea was to create a property, which is a MultiBuildValue property, so depending on the build it would have a default GUID and an alternative GUID, but as per on the other screenshot you see, custom properties cannot be set as ProductCode.
Zsolt
Re: Custom ProductCode GUID based on build type
Hi Zsolt,
I'm afraid that having different Product Codes for the builds in the same project is not possible. Can you please give me more details about your scenario and why would you need that?
