TheRocket
Remove File after Reboot - No Translations - AIRemoveFilesReboot*
Hello!
I would like to report the following issue:
You are working with AI version 23.4 with a new enterprise project.
You add a File Operation to your main folder, of type "File Removal" and select the options "Execute upon system reboot" and "Remove On Component Uninstall"
2026-02-03 18_39_42.png (9.28 KiB) Viewed 24389 times
Entries are automatically added to the ActionText table with missing translations:
AI_AiRemoveFilesRebootDeferred: ActionText.Description.AI_AiRemoveFilesRebootDeferred
AI_AiRemoveFilesRebootImmediate: ActionText.Description.AI_AiRemoveFilesRebootImmediate
AI_AiRemoveFilesRebootRollback: ActionText.Description.AI_AiRemoveFilesRebootRollback
A warning is show in the Notifications pane:
The following Localization Identifiers do not have translations:
ActionText.Description.AI_AiRemoveFilesRebootImmediate for languages:1033-English (United States)
and repeats for 5 others strings.
Note also that projects migrated from older versions to 23.x also throws this error on conversion.
Re: Remove File after Reboot - No Translations - AIRemoveFilesReboot*
I've forwarded this to our development team and translations for these missing strings will be added in a future version. We will notify you on this forum thread.
It is important to note that this is not an error, but merely a warning that you can safely ignore. Could you also send us the other 5 strings?
I've reproduced these:
Notification: The following Localization Identifiers do not have translations:
Property.ARPCOMMENTS for languages:1033-English (United States)
ActionText.Description.AI_AiRemoveFilesRebootRollback for languages:1033-English (United States)
ActionText.Description.AI_AiRemoveFilesRebootDeferred for languages:1033-English (United States)
UIText.SharePointLogNoWsps for languages:1033-English (United States)
UIText.SharePointLogActivateFeature for languages:1033-English (United States)
You can add your own translations in the Translations page --> Project Strings tab:
TheRocket
Hello!
Here is the complete notification message in 23.4:
ActionText.Template.AI_AiRemoveFilesRebootImmediate for languages:1033-English (United States)
ActionText.Template.AI_AiRemoveFilesRebootDeferred for languages:1033-English (United States)
ActionText.Template.AI_AiRemoveFilesRebootRollback for languages:1033-English (United States)
This is likely the 6 cells in the Action Text table for the 3 actions added.
Thanks!
Thank you for the information.
We will let you know when we add default translations for these strings.
This improvement has been added in version 23.8 of Advanced Installer.
