clint
Problem uninstalling my app
Using A! 19.3
- I have three different scenarios in my setup which the user can choose from.
- I have a custom action to register and MyServer.Exe using \regserver
-The MyServer.Exe file is only installed for 2 of the 3 scenarios, and not the 3rd.
However, I forgot to use a condition on the custom action to only call \unregserver on the file if scenerio 1 or 2 are used.
Now, when uninstalling, the error comes "The file 'MyServer.Exe ' is not marked for the installation"
I tried creating a new produkt, using the condition, but MSExec uses the cached Msi.
If I swap this cached msi out with the corrected one (renaming it to the expected name as the cached msi), the app uninstalls alright.
But, I cannot expect customers to do this also.
How can I otherwise get the system to Uninstall my app?
Thank you in advance!
Clint
clint
Re: Problem uninstalling my app
Well, the 2nd time around this failed also. It seems Windows is getting a cached msi from somewhere else other that c:\windows\installers\
clint
Ok. We used the Advanced Uninstaller 13 and the error message came, but it did uninstall the application.
Thank you for the tool.
clint
Hello Clint,
I am glad to hear you managed to find a solution for this.
Please note, however, that Advanced Uninstaller (despite the name) is not our tool. :D
The solution I would have offered here would have been to try and recache the MSI, using the approach explained here:
Recache MST
Let me know if there is anything else I can help you with and I will gladly assist.
