Hello John,
It appears that the duplicated custom actions were already present in the older version of the project, so they were not introduced during the conversion, at least not when converting from version 16.9 to 23.1.
I tried to remove the duplicates based on my understanding of your custom action logic. However, since this depends on how you expect the actions to behave, I cannot guarantee that the remaining configuration matches your intended workflow.
I also noticed that the duplicated custom actions were using different conditions:
and
SqlConnectionOK = "1" AND (&SQLINSTALLATION = 3)
Therefore, I am not sure which one should be kept, as this depends on your intended installation logic.
- sqlcondition.png (62.46 KiB) Viewed 756 times
The red loading error warnings have also been fixed in the attached project.
Could you please build the project and test the resulting setup package?
Let us know if you encounter any further issues.
