petecoales
Error building project
Thu Jun 09, 2016 12:05 pm
Hi
I'm receiving the following error when trying to build my project:
Error calling MSI API: 1627 Method: MsiDatabaseCommit Table: AI_SQLScript. Extended Error: 1: 2213 2: C:\Users\pete\OneDrive\Documents\Installer Projects\Communicator\afinitis.communicator.16_4_1.msi 3: 4: .
Advanced Installer 12.2.1 build 64247
*** Stack Trace (x86) ***
[0x7574dae8] RaiseException()
[0x77e4872d] CxxThrowException()
[0x0179d1ba] -----
[0x013c0000] MODULE_BASE_ADDRESS
Any ideas?
Pete
Re: Error building project
Thu Jun 09, 2016 2:25 pm
Hi Pete.
It seems this happens because your project contains duplicate or incomplete rows in the "AI_SQLScript" table. I'm not sure how your project reached this corrupt state.
Can you please send us your AIP (project file) to support at advancedinstaller dot com, so we can investigate it and try to find the problem? Also, can you please try to isolate this error in a test case scenario? Maybe you can find a working version of your project and starting from that working project state try to find out a pattern (test case) which always replicates this error. This would be very useful for us so we can isolate and investigate this issue.
Jon Conyers
Fri Jan 25, 2019 10:04 pm
I had a similar problem. I added different SQL scripts to my AIP and received the 1627/2213 error set. I checked around on another thread and discovered that my file names night be too long. I shortened the file names and the AIP compiled without error.
Hope this helps the next victim of 1627/2213.
Jon
Mon Jan 28, 2019 10:25 am
Hi Jon and welcome to our forums.
Thank you for sharing the solution with us, I'm sure it will help other users facing the same issue.
Kai
Fri Oct 02, 2020 10:04 am
For us it has been also a problem with the names of SQL scripts. It seems that they contained invalid characters when autogenerated. After changing the names building was successful once again.
Contact:  Website
Tue Oct 06, 2020 4:19 am
Thank you for your insights on this.
Fri Mar 01, 2024 11:48 am
This has been fixed in version 21.5 of Advanced Installer.
