agvinh
Execute SQl Query with a SQL data coumm data length [nvarchar](MAX) cause "allocation" error.
I meet a problem when execute custom SQL query action to get a field from SQL Server database's column with the data type "[nvarchar] (MAX)"
CREATE TABLE [tbl_Config](
[Variable] [nvarchar](50) NOT NULL,
[Value] [nvarchar](MAX) NULL,
[Description] [nvarchar](150) NULL,
[Created] [smalldatetime] NULL DEFAULT (getdate()),
[SoftwareGroup] [varchar](50) NULL
) ON [PRIMARY]
The following sql is OK: SELECT [Description] FROM [tbl_Config] WHERE [Description] = '\\IP_ADRESS\'
But executing this sql is failed: SELECT [tbl_Config].[Value] FROM [tbl_Config] WHERE [tbl_Config].[Variable] = 'Val1'
The errors in log:
OnSqlFetch: bad allocation
OnSqlFetch: SQL script: [SqlQueryDatabaseSize] FAILED !
OnSqlFetch: Aborting install...
CustomAction SqlQueryActionDatabaseSize returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 18:51:22: SqlQueryActionDatabaseSize. Return value 3.
Please help me with the above error.
Attached is the Advanced installer project and log file.
I am using Advanced installer version 14.4.2
With best regards,
Vinh Nguyen
SQLSample.aip
(44.52 KiB) Downloaded 355 times
logB637.log
(117.43 KiB) Downloaded 285 times
agvinh
Re: Execute SQl Query with a SQL data coumm data length [nvarchar](MAX) cause "allocation" error.
I find a way to workaround by replacing the sql SELECT [Value] FROM [tbl_Config] WHERE Variable = 'Val1' with the following:
DECLARE @val AS NVARCHAR(500)
SELECT @val = [Value] FROM [tbl_Config] WHERE [Variable] = 'Val1'
SELECT @val
Now it works as I expected
I'm glad you found a workaround solution.
We'll also start investigating your first query scenario which didn't work and get back to you as soon as we have a conclusion.
Hello again,
We have further investigated this and indeed seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing this to our attention.
We will update this thread as soon as the fix will be available.
This was fixed in version 14.6 of Advanced Installer released on February 19th, 2018.
