redseujac
How to add disk space indication?
Installer Enterprise > Classic theme > Enhanced UI (only install)
For the following dialogs:
- FolderDlg
- StartMenuShortcutsDlg
- VerifyReadyDlg
I'd like to have indications of the required disk space and the available disk space.
How can I do this?
Re: How to add disk space indication?
The properties you are interested in are:
-- PrimaryVolumeSpaceRequired
-- PrimaryVolumeSpaceAvailable
To have these properties set correct you will need to set the following properties like this:
- go to the "Custom Actions" page and add a "Set installer property" custom action before the "Wizard Dialogs Stage -> Searches" action group
- set the "Property" field to:
AiEarlyValidate
- set the "Value" field to:
- create another "Set installer property" custom action under it
PRIMARYFOLDER
APPDIR
The custom actions should use the following condition:
NOT Installed
If you are not using Enhanced UI you only need to set the "PRIMARYFOLDER" property and not the "AiEarlyValidate" property too.
redseujac
Thank you very much. I did what you suggested and it's perfect indeed :D
