sjeslis
MSI Created Global Property Not Seen By Merge Module
My parent MSI creates a global property (OFFICE_2007_PATH) set by a registry location search:
MSI (c) (A4:94) [14:18:32:173]: PROPERTY CHANGE: Adding OFFICE_2007_PATH property. Its value is 'C:\Program Files (x86)\Microsoft Office\Office12\'.
I have a file component in my merge module (MSM) that has an install condition of:
OFFICE_2007_PATH
the component doesn't not get installed:
MSI (s) (58:F8) [14:19:03:705]: Component: CIFOutlookPlugin.dll.4E72A4E1538744C6A2EC5B2DE0D2CEDE; Installed: Absent; Request: Local; Action: Null
which tells me the Merge Modules does not see the global property.
I thought this was possible to do it this way?
Scott Jeslis
Senior Software Engineer
Cicero, Inc.
Re: MSI Created Global Property Not Seen By Merge Module
All properties from a merge module are called from the main MSI by appending the merge module GUID to their name(this is standard requirements from the OS). So from your MSI you need to set the following property:
OFFICE_2007_PATH.4E72A4E1538744C6A2EC5B2DE0D2CEDE
