enigma
Uninstall an application automatically after installing it
I need to be able to uninstall an application automatically after it is installed.
Sounds weird isn't it. If an application is needed then why one needs to remove it right after installation?
But my case here is different. I have an application that is packaged into an installer. So when the installer is clicked, the application is installed and the application is run in order to perform an action. After that, the mission of the app is considered completed and should be removed.
So I need to be able to uninstall it immediately upon a successful installation.
Is there anyway to do this in Advanced Installer?
Cosmin
You can do this by using custom actions.
In the "Custom Actions" page, under "InstallExecuteSequence->InstallFinalize" you create a Exe with working Dir custom action. You set "Asynchronous execution, do not wait for return" in the "Execution Properties" section and you set the "Full Path" to:
msiexec /x [ProductCode] /qn
Note that /qn will make the uninstall silent.
In the "Install" tree you create a Launch File or Open URL custom action which will launch your application.
cosmin
enigma
cosmin wrote:Hi,
cosmin
I am sorry, I do not understand what you mean.
You said that
But there is no "InstallFinalize" parameter anyway on the Custom Actions page. There is a "InstallExecuteSequence" folder. And under that folder there is a "uninstall", "Rollback", "Install" and "Commit" folder. But "InstallFinalize"? It's no way to be found.
And you said that
I don't get this. I thought we have done what is needed in the "InstallExecuteSequence" and hence do not need to define a new action under "Install" folder tree?
I have a few questions here:
  1. How to specify the ProductCode? It's generated by Windows Installer and we usually don't know about it
  2. I read the help online, and found that one can replace ProductCode with the MSI path. I think it's easier to specify the MSI path rather than specifying the ProductCode for uninstallation purpose. This there anyway to get it?
Cosmin
You can add the "InstallFinalize" folder by right-clicking on the "InstallExecuteSequence" folder, you go to "Show Standard Action", then you go to "Before Finalization" and then on the bottom of the menu you click "InstallFinalize".
In order to execute your application after installing it, you need to make a custom action. That custom action will be in the "Install" folder, under the "InstallExecuteSequence" folder.
You don't specify it, you copy/paste msiexec /x [ProductCode] /qn in the "Full Path". [ProductCode] is a formatted property name which during installation will be expanded to the real product code.
cosmin
enigma
cosmin wrote:Hi,
cosmin
Great, this is exactly what I have been looking for. Thank you for your help
enigma
Now I realize that after the uninstallation, the empty application directory is still there, is there anyway to remove the empty application directory?
Cosmin
You can do this using the "Folder Removal" dialog.
In the "Files and Folders" page you right-click "Application Folder" and select "Properties". In the "Remove" tab you check "Remove folder (only if empty)" and in the "Remove On:" combo you select "Component Uninstall".
http://www.advancedinstaller.com/user-g ... ialog.html
Cosmin
Return to “Feature Requests”
