vidur
Custom Action under user
I have an installer that is launched as "SYSTEM" process at times. I need to launch one of my applications as a user process. Is there any way i can launch an exe as a user in Custom action.
Thanks ,
Re: Custom Action under user
I assume you want to prevent the application from elevating to administrator level at the end of the installation process, right?
Please note that you cannot do that if the "Run as administrator” option from the “Install Parameters” page is enabled or the installer is launched right from the beginning using the "Run as administrator" context menu option.
Please let us know if I misunderstood your scenario.
vidur
Thanks for your reply:
- Not exactly. You see our installation is done using a system server so it is always run under "SYSTEM" user .
In this case i need to run a custom action under the current user. Is there a way i can run an exe under a user using custom action?
I'm afraid that you cannot start a non elevated task from an elevated one.
You can also take a look on the How to start process after install, as ordinary user? forum thread which debates a similar subject.
