Hello
I'm trying to set up the auto updater functionality with our setup.
Our Setup allows the installation of multiple instances at install time (the user can choose a name for the instances).
The setup saves the product version in the registry (HKLM\Software\CompanyName\[ProductName]\Version).
Example.
Instance1 -> HKLM\Software\CompanyName\Instance1\Version
Instance2 -> HKLM\Software\CompanyName\Instance2\Version
I want the updater to search in the registry for the version (Installed Detection "registry value search").
How do I have to specify the registry value in the properties page of my updates configuration file project to achieve this?
I tried "HKLM\Software\CompanyName\[ProductName]\Version" but no luck. [ApplicationName], [APPNAME], [InstanceId] also didn't work.
I can see the correct "ApplicationName" in the updaters INI file, but how can I tell the updater to use it in the registry search?
Thank you for any help.
Best regards
Stefan
