Fernandes
Code Signing Certificate
I'm new to code signing an installer.
I came across comodo-codesigning-ssl
https://www.gogetssl.com/comodo-ssl-cer ... gning-ssl/
Will a certificate obtained from the above issuer work with advanced installer (i.e signing an installer I'm creating).
I also came across startssl (https://www.startssl.com/?app=39) . However, I read that the certificate provided by startssl expires even if we add a time stamp to them.
Will a certificate from startssl work with advanced installer?
If a certificate expires, then will the installed application still work on the system or will it stop working and give error?
thanks in advance
Re: Code Signing Certificate
Hello Fernandes,
A digital signature is used to help authenticate the identity of the creator of digital information. Digital signatures are based on digital certificates. Digital certificates are verifiers of identity issued by a trusted third party, which is known as a certification authority (CA). It doesn't matter from which you get the certificate as long as it is a valid one.
Digital signatures help establish the following authentication measures:
  • Authenticity
  • Integrity
  • Non-repudiation
The Digital Signature feature from Advanced Installer allows you digitally sign your installation package. By digitally signing your installers and products in Advanced Installer, you will increase your user's confidence in you and your company, giving them peace of mind about your software.
Please take a look on the Digital Signature article which may be useful to you.
Most likely, after the certificate expires you will get the Unknown Publisher message on Windows Vista or above, during installation.
dms
As I understand it not if you use the timestamp feature as well. So long as you build the installer whilst your certificate is still valid and add the correct timestamp url then even if someone installs your software via that installer it will still show up as being from a trusted source because at the 'time' that it was built the certificate was valid.
Dom
SamiUllah
When I build sign setup and test on your computer then does not show unknown publisher message and When I try on client computer then show unknown publisher message working properly in both condition but I use Advanced installer trial v19.7 and used built in certificate.
Can any solution?
Hello Sami and welcome to our forums,
From what I can see, you already have an ongoing thread with my colleague over the email.
In order to avoid duplicate threads, please continue it there.
