ometa joey
Configure dynamically SSL on IIS website - Error 4020
I am having troubles with dynamically configure an IIS website with the ability to enable SSL and select a SSL certificate.
I have attached two files.
Extract from verbose logging from MSI installer:
AI_IIsConfig: Installing "Ometa REST Service"
Error 4031. There was an error while processing the digital certificate for Web Site "Ometa REST Service".
MSI (s) (B4!1C) [14:20:35:299]: Product: Ometa Software Suite -- Error 4031. There was an error while processing the digital certificate for Web Site "Ometa REST Service".
Error 4020. There was an error during the IIS configuration process.
Your original IIS configuration will be restored.
MSI (s) (B4!1C) [14:20:36:280]: Product: Ometa Software Suite -- Error 4020. There was an error during the IIS configuration process.
CustomAction AI_IIsConfig returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 14:20:36: InstallFinalize. Return value 3.
Is this the proper way to configure this and is it possible to receive more logging to find out where the error occurs?
Version info:
Advanced Installer 11.9 build 63002
Re: Configure dynamically SSL on IIS website - Error 4020
I'm not so sure why this happens. Firstly, can you please make sure you set the "Port" field of the added HTTPS binding to the formatted reference of your port property like this:
[REST.HTTPS.PORT]
and see if this helps? If not, then please send us the .AIP (project file) and a full verbose log of the installation to support at advancedinstaller dot com so we can investigate them.
ometa joey
Hi Daniel,
That did the trick!
Many thanks,
Joey
You're always welcome Joey.
I'm glad you got everything working.
