Arno
Feature List
Here a couple of features I'd really like to see:
- Dialog repository editor. Being able to delete from the repository, as well as edit the dialogs from the repository. [Edit:] Never mind this item, today by accident I happened to find the repository list where I at least could remove dialogs in the repository ;)
Since I'm working with .NET 2.0 projects in conjunction with this installer, I would really like to see the following. Personally I would call them mandatory features:
- Multiselect add files to the assembly list. In fact, I would reorganize this part of AI as follows:
* In the files'n folders pane, add a special folder "Global Assembly Cache".
* Instead of first adding assemblies to an arbitrary targetfolder and then into the "Assembly" pane, allow assemblies to be added to the target special folder GAC immediately.
* When the GAC special folder is selected, the right pane should be divided in an upper- and lower half. The upper pane listing the assemblies added to the target GAC, the lower pane showing the assembly attributes of the currently selected assembly. Basically the same pane you see when you select "Assemblies" from the main menu on the left.
- Please oh please import the "ProcessorArchitecture" attribute upon adding assemblies. You really want the end-user to add this attribute to each assembly up to a hundred of times?
These changes would make working with .NET 2.0 assemblies and the target GAC so much more userfriendly :)
A.v.Harskamp
Kraan Bouwcomputing B.V.
http://www.kraan.com
Daniela Petrescu
We will consider adding these features in a future release.
Sorry but i cannot give you an ETA for now.
Thank you for your suggestion!
Daniela
_________________
Daniela Petrescu
Advanced Installer Team
Return to “Feature Requests”
