FrodoH
Disable analytics
Fri Jun 02, 2017 4:39 pm
Is there a client install time switch for disabling Analytics for customers that prefer to protect their privacy? That is, can customers chose to opt out of Installer Analytics reporting at setup run time?
cnom
Re: Disable analytics
Tue Jun 06, 2017 10:21 am
I am searching for this option also!
As well as a way to disable it in the packaged installer before being shipped.
A possible way could be to disable the option "Customer Experience Improvement Program (CEIP)" in the Settings->Customer Feedback"
Tue Jun 06, 2017 3:27 pm
The Installer Analytics will be enabled in the setup package if the AI_IA_ENABLE is set. You can set this property at run time to an empty property and the Analytics will not be enabled.
e.g.
Setup.exe AI_IA_ENABLE=""
Let me know if that helped.
Return to “Installer Analytics”
