t3knomanzer
Re: GitHub Integration - Auto-Updater
Wed Jun 24, 2020 6:19 am
I updated today to 17.1.2 and same issue.
Thu Jun 25, 2020 3:59 pm
The ETA is ... today :)
Please have a look over the following how-to for more infromation about this:
Updater integration with GitHub - Beginners Oriented How-To
Hope that will be of help for you!
Kallex
Sat Jul 18, 2020 11:13 am
t3knomanzer wrote:
Wed Jun 17, 2020 7:31 pm
I'm however trying to set it up and I can't seem to get it to work and the documentation is pretty vague for this feature https://www.advancedinstaller.com/user- ... ntegration
The first step in the documentation says:
1. Set "Updates configuration file URL" to a GitHub updates URL
I am assuming by Github updates URL you mean the url to an updates config file in github?
What information does that config file need to contain?
I have tried, using an empty file, using a file with just ;aiu; on the first line and using just my old updates config file.
I was also excited about this new feature (been using AI for years, great to see it keep surprising me) and would immediately like to start using it.
I also had no idea what to put in GitHub updates URL.
Can you specify in detail as an example, what URL from the repository I should use?
EDIT: I leave my reply here, but really thorough looking example is in Sample Projects section of the Forum - about GitHub Updater Integration:
viewtopic.php?f=7&t=45614
Your team never disappoints :-)
Mon Jul 20, 2020 8:16 am
I am really glad this feature is of help for you and that you have also found the how-to from the Sample Projects section.
Thank you for your kind words! :)
Return to “Feature Requests”
