iSlide
Why google is depended?
Use network spy for advanced installer analytics, the google is used for data analysis?
In China, due to website blocked of google, the setup exe start takes long time to initialize with ui, same with close.
Please help me out with this issue.
I've already uncheck the use analytics function, it still visit google now unless reverse my code.
I've already contact your email support, no one reply it.
If so answer, please refund all my money!
Re: Why google is depended?
I am not sure why but it seems you did not reach our first email reply. However we replied you by email again and it seems you got everything working.
As a side note, please be aware that a google.com http request is done as implementation part of our "Run only if an active Internet connection is found" predefined launch condition from "Launch Conditions" page. So, you should check and see if this launch condition is activated into your setup project.
If you encounter any further issues do not hesitate to write us back.
iSlide
It works now,
Any question is, how to view specified datas in google analytics?
Only installations number sync to google?
This is not possible. Unfortunately we do not support anymore the integration with Google Analytics.
Return to “Installer Analytics”
