marceloavf
Abort installer if application is opened
Hi everyone!
I'm creating an installer and when it's running to install and user let some file open it goes to MsiRMFilesInUse Dialog, but at the end it's not closing the app, so I decided to create a custom action to allow us to have more control under it.
The problem is that I can't finish the installer in case that the user cancel to end the app proccess, I'll list below the proccess that I'm trying to do it.
First of all I detected if the proccess is running
Then I ask the user to allow us to close it or cancel
If OK button is pressed, I close the app
If CANCEL button is pressed, I try to abort the installer, but nothing happens at this point and installation continues normally
Thank you!
Re: Abort installer if application is opened
In order to achieve what you want, you can use a "Display error message" instead of a VBScript custom action.
There are two ways of running a VBScript custom action. One of them is to run it as an inline script (as you did) and the second one is to use a "Launch attached file" custom action. The main problem here is that an inline VBScript custom action return code is always interpreted by Windows Installer as a success, thus you can not force your installation to fail using it. If you want to force your installation to fail based on a VBScript custom action, you should use a "Launch attached file" custom action instead.
Or you can also use a "Display error message" custom action, the installation will fail upon pressing the "Cancel" button from the "MessageBox", giving the user a message which will inform him that the installation can not continue if the does not stop / terminate the respective process.
In order to achieve those said above, you can go to "Custom Actions" page, add a "Display error message" custom action with the message that you want and the condition as it follows:
BTN_PRESSED <> "IDOK"
This way, if the user presses the "Cancel" button from the "MessageBox", the installation will fail.
Let me know if this helps!
marceloavf
Catalin wrote:Hello,
Excellent Catalin, I get it working using `Display error message` and the condition below:
BTN_PRESSED AND BTN_PRESSED <> "IDOK"
Because sometimes the message box doesn't appear.
Thank you!
You're always welcome!
I am glad you got this working!
