JustinC
Re: Useful to have option to get Product Version from main .
I'd just like to add my vote to this request. I've only discovered advanced installer today and have been very impressed. Allowing the version to be taken from the main executable would mean we could remove some custom build logic. Perhaps the product and package codes could be generated from a hash of the version string? This would also work quite nicely with the visual studio integration too. Changing the version number manually with Advanced Installer is something I would just not do, as it duplicates a change. If the installer product version were linked to the main executable, I may then sometimes create installers from within visual studio too.
I hope this makes sense. I wish I'd moved away from deployment projects sooner!
Justin
Cosmin
Hi Justin,
This improvement is already on our TODO list and will be available in a future version. I increased its priority.
Cosmin
AlexN
It look like that version reading not supported for 5 years :(
What is the easiest way to do it now yourself?
Cosmin
The current version supports this internally, but it doesn't have an UI for it yet. If you want, I can enable it in your project. Simply send your .AIP (project) file to support at advancedinstaller dot com and mention the file from which you want to retrieve the version.
Cosmin
AlexN
thanks but I need to do it in every build in our CI server. Can I use command line for it?
Cosmin
No, it can be enabled only by editing the .AIP (project) file.
Cosmin
AlexN
Is it means that in addition to $1000 we must create our own AIP patcher?
Cosmin
No. This feature is currently not supported officially. It is on our TODO list and it will be available in a future version.
Cosmin
SkafeverDe
My vote too on this feature request
Sorry, it seems we forgot to update this thread. The good news is that this feature is now supported in the GUI of Advanced Installer for all projects.
Just go to Product Details page, right click in the Product Version field and select "Set version from file...".
My pleasure.
prasanth.tech
Re: Useful to have option to get Product Version from main .exe
HI,
Please let me know whether this mentioned feature of extracting version from main executable has become standard feature in the installer.
Prasanth
Hi Prasanth and welcome to Advanced Installer forums,
If you have other questions, please let me know.
Return to “Feature Requests”
