The vacuum cleaner market is a very competitive area with thousands of models, from canisters to upright vacuums, cord and cordless, bagged or bagless… and the newest member participation for a new generation – the robot vacuum cleaner TheKingLive. To compare robot vacuums with traditional ones, it is really like a new wind with technologic functions like voice command or cleaning programs. Robot vacuums are products for busy people who find it difficult to spend 30 minutes every day on regular house cleaning or lazy people who find it tiring to raise and move the vacuum cleaner to do the clean up.
Therefore, we write this article with the hope that it will give you some information on the best robot vac that is currently receiving very high reviews from customers, so that if you are interested in buying one, you can have some information for your reference.
1) Eufy Robovac 11s
This model has been voted in a reputable survey to be the best robotic vacuum cleaner of 2018. The latest model is already reengineered to be the slimmest Robovac but produces very quiet operation and increased suction power at 1300 Pa. With such a strong capacity, this small round machine can work up to 100 minutes on hardwood floors with a very smooth running mode.
There are two special features with the Eufy Robovac 11s. First is BoostIQ Technology that will allow you to increase suction power within 1.5 seconds. This is very helpful when you want extra vacuuming power to get the best clean. Everything is immediately available within the reach of one button on the remote control. Secondly, this 2.85’’ machine has an anti-scratch tempered glass-top and has sensors for evading obstacles or avoiding falls. This robot is sold for $167, which is quite inexpensive among robot vacuums.
2) iRobot Roomba i7
This may be the most excellent model up until now in the robot vacuum cleaner market, together with its high price. The Roomba i7 has a precise map, which can record multiple floor plans and measurements to clean your whole house. As well, it can remember precise measurements to cover all house corners. This software of iAdapt 3.0 has been patented, and makes it one of the smartest technologies for a robot vacuum.
What’s more? This model is ideal for homes with pets, as it can suck up 99% of pet allergens. The unique brushes will prevent the machine from being tangled with hair or threads. Also, the brushes will adjust and become flexible to stay in constant contact with carpets and hard floors.
You can use the app control for monitoring. For example, you can program your voice “Roomba, clean my room” and it will appear quickly at the door, cleverly cleaning your entire room. This app can be customized to your house demands and be controlled by diversified providers, from the manufacturer, or Amazon Alexa, or Google assistant.
3) Neato Botvac d7
This has always been on the list of what is the best vacuum cleaner for years since its product launch. The design of its D-shape makes it very flexible in cleaning corners, which are often hidden places with the worst dirt. The cleaning map can be set up with a laser-guided system which enables you to navigate and map your house. You can also program its running cleaning route that is best appropriate with your house, such as no-go lines which only runs in straight lines, instead of a random pattern, for a better clean.
The battery life is amazing with lithium-ion batteries and can clean thoroughly for up to 120 minutes. This duration is quite enough for a 3-story house. The machine is also super smart and can remember multiple floor plans and allow the user to program no-go lines so the robot knows where not to clean.
It can be very difficult to identify what is the best robot vacuum, but this Neato Botvac d7 is very functional with quite a competitive price.
4) Ecovacs Deebot n79s
This model of Ecovacs has a very elegant design, reminding of the CD-player decades ago. Even with its tiny size, the robot is ready to solve any mess in your house, with its two-side brushes and a main brush which will allow it to sweep, lift, and vacuum an entire area (Auto mode), a tight space (spot mode), or the floor edge (edge mode).
You can double the suction power by two times while the sound level remains the same. The large dustbin holds 520ml which is enough for a full-time cleaning of 100 minutes. When it is out of battery power, it will automatically run to its dock for charging without interfering with the humans. This function is very convenient and avoids unnecessary frustration when you want to clean up your house, but find out it has been out of battery power and needs to charge for hours, right?
5) Shark Ion
The Shark Ion 750 App-controlled Robot Vacuum has been very popular as it is always among best sellers in big supermarkets, or appears in all robot vacuum cleaner reviews for its friendly price and reliable operation. It has a stiff brush roll that captures long and short hair, dander, and allergens that can quickly accumulate in your house corners. The lithium-ion battery can make it last around one hour running at max power mode. All the functions of a traditional upright vacuum now have been turned into a 5.5 pound small machine. This model is reviewed to be very easy to assemble, like taking in/out the dustbin without causing any noise. Similar to almost all other robot vacuums, it can be controlled by Amazon Alexa.
According to interviews with customers, the Shark Ion 750 satisfies them in the navigation management and the detangle brush setup. With this machine, the teeth that are arranged between the dirt container and the brush removes the hair and then sucks it inside the dirt container in a very effective way.
In summary, it is very difficult to give a clear statement about which is best vacuum cleaners in the world as each model has its advantages. But summarizing from our own experiments and customer robot vacuum reviews, we wanted to give you some recommendations for consideration if you are looking for one for your house.
