The most comfortable hiking boots are critical to your performance. Unlike walking shoes, best-rated hiking boots need to be supportive, lightweight, and waterproof to be your best company when you have to deal with mud, rocks, streams, and even insects. Since there are many models of hiking boots from different manufacturers, choosing the most appropriate can be a challenge. So let us take you through a review of top rated hiking boots to give you some pointers on the best options available on the market. Let’s dive right in!
1. Salomon X Ultra 3 Mid GTX
Salomon X Ultra 3 Mid GTX is one of the best lightweight hiking boots as it’s a perfect combination of high wearing comfort and exceptional grip in a low weight model. We’re impressed with its robust toe protection and stable chassis, which are built to get you out there to any hiking adventures. Moreover, the X Ultra 3 Mid GTX from Salomon is guaranteed to satisfy even the most demanding customers with its firm midsole, as it offers hikers sufficient isolation from the sharpest rocks. In case you haven’t known, many hikers to the Grand Canyon have chosen this model for one of the most memorable trips of their lives.
2. Merrell Moab 2 Mid WP
If we were asked to describe Merrell Moab 2 Mid WP in one word, we would choose “comfort." With a cushioned collar and supportive footbed, it’s comfortable and flexible for long trail days. Merrell Moab 2 is the upgraded version of its older brother to offer you better underfoot protection, thanks to its extra pad in the heel. We reckon this area of improvement is the critical reason Merrell Moab 2 Mid WP earns a spot on most hiking boot reviews.
Merrell’s Moab shoes are well-known for their low weight, and Merrell Moab 2 is one of the lightest in its family. With only 2 pounds, this hiking boot is the ideal choice for hikers and backpackers who are keen on lightweight hiking boots. When it comes to price, Merrell Moab 2 Mid WP is the best value hiking boots as it comes at only $135. However, it doesn’t mean you’ll have to sacrifice price for performance, as it’s included a new insole and a durable suede upper.
3. Lowa Renegade GTX Mid
We believe Lowa is proud of its Renegade GTX Mid as it’s comfortable straight from the box. We’ve tested this model on extended hiking and scrambling up in the rocky mountains of Yellowstone National Park, and it doesn’t disappoint. Its midsoles provide hikers with sufficient isolation from rocks for optimal comfort.
If you’re looking for the best waterproof hiking boots, then Lowa Renegade GTX Mid should be the first in your shortlist, as it has a solid leather upper. What is more, this beast is also built with a water-repellent coating to ensure it doesn’t leak a drop. Thinking of crossing and standing in streams to enjoy the beauty of nature? Get the Renegade GTX Mid from Lowa to your next adventure this summer.
4. Salomon Men’s Quest 4D 3 GTX
Salomon Men’s Quest 4D 3 GTX is one of the best hiking boots for men, as it’s sufficiently robust thanks to SensiFit tech. What does this technology mean? Well, it cradles your foot from the midsole to the lace to ensure debris and small stones won’t get into your boots. Are you worried that robust hiking boots are usually heavy? Fret not! Quest 4D 3 GTX from Salomon is crafted as a mid-weight hiking model to support your ankle stability, allowing you to tackle the roughest terrain with ease.
Men's hiking boots review always includes Quest 4D 3 GTX from Salomon as it has an outstanding feature called Contagrip sole, which provides excellent traction on a range of multiple surfaces, be it on or off the trails. Quest 4D 3 GTX is, true to its name, has the 4D Advanced Chassis to give hikers superior torsional balance on rocky trails.
5. Hoka One One Sky Kaha
Hoka One One Skye Kaha has a Vibram Megagrip sole, which combines grip and durability perfectly to keep you steady on your feet, regardless of how uneven the trails you’re hiking on. Plus, Sky Kaha hiking boots from Hoka One One is an eVent waterproof boot. So even though it rains or snows while you’re hiking, you do not have to worry about getting wet feet.
Sky Kaha is a high-rise hiker with adjustable lacing systems to give users flexibility in either loosening or tightening it up, depending on various conditions of the trails. We reckon Hoka One One Sky Kaha is one of the best hiking boots for women, as it’s not only exceptionally soft, highly supportive, but also fashionable.
6. Merrell Zion Mid Waterproof
Are you concerned about the bulky feel of regular hiking boots? Are you looking for hiking boots that are just as light as comfortable as your running shoes? Then, look no further! Zion Mid Waterproof from Merrell is your boots. Its flexible molded-EVA midsole ensures a light feeling on your feet. Also, its mesh and leather upper gives you supreme traction.
Merrell Zion Mid Waterproof is one of the best lightweight waterproof hiking boots, as it weighs only 1lbs (816g). Besides, its waterproof leather and mesh upper, together with the M Select Dry impermeable membrane lets moisture escape and keeps your feet dry. Zion from Merrell is deserved to be evaluated as the best hiking boots of all time.
➤➤➤ See Also: Top Rated Hiking Boots - The Best Hiking Boots
The bottom line
High-quality hiking boots should be made of breathable and waterproof materials. More importantly, they should fit you perfectly to avoid blisters. A standard tip to try on hiking boots that hikers often share is to put your thumb between the back of your hiking boot and your heel. If your thumb does not reach the bottom of your boot, then you’ve got a good fit. The best hiking boots usually have a curved exterior sole, which allows the boots to bend when you climb over rocks and roots. Also, make sure you look for polypropylene or polyurethane midsole as it provides excellent support for hiking trips.
Best hiking boot brands are Salomon, Lowa, and Merrell. Therefore, if you’re hiking next week, do not get overwhelmed with many available models, stick to those from these three brands only. We hope our post has given you useful information to search for the most appropriate hiking boots. Click share if you like this post, and feel free to leave us your comments below.
