arossert
Upgrade using cmd on non default folder
I have an issue with my installer built using Advanced Installer 14.5.2.
When I install the program on a different drive (like F:) the upgrade is working perfectly if the "exe" is executed with UI (double click on the "exe" file) but when I try to run it from a command line like so:
START "" "installer.exe" /quiet /l*v "installer.log"
The installation is ignoring the fact that it is installed in F drive and install again on C drive.
I have looked at the log output in both cases and can see that when the installer executed in "quiet mode" does not set the TARGETDIR to the the current volume
Log from the UI installer that is missing in quite mode:
MSI (s) (7C:48) [11:46:37:203]: PROPERTY CHANGE: Modifying TARGETDIR property. Its current value is 'C:\'. Its new value: 'F:\Program Files\****'.
Any reason for that to happen? I do have the "Use original installation path when upgrading" set.
How can I fix that?
Re: Upgrade using cmd on non default folder
In order for me to further investigate this, could you please forward me the following resources:
- a copy of the .AIP file
- a download link for the older version
- a download link for the newer version
- the full log
by e-mail at support at advancedinstaller dot com?
