How to display interactive user message during an Intune System deployment
Let's suppose that you need to create a suite installer that wraps up one (or more) packages and it is silently deployed through an Intune deployment run under System account.
There may be the case when you need to display a UI message to the logged on user prior to silently installing the suite installer (through an Intune deployment run under System account). This requirement can be achieved using the "ServiceUI.exe" tool to launch a System account process in user interactive mode. The "ServiceUI.exe" tool is available within Microsoft Deployment Toolkit (MDT).
The currently attached sample includes a suite installer project with the following functionality:
1. incorporates two prerequisite packages
2. includes a custom action that launches the ServiceUI.exe tool to execute a PowerShell .ps1 script that displays a message box
3. the prerequisite packages are installed only if you agree with the ps1 message box otherwise the suite installer just exits
Here it is attached the sample:
sample.zip
(788.13 KiB) Downloaded 5382 times
Here are the detailed steps to create the suite installer project:
1. create a new Architect project type
2. go to "Product Details" page and uncheck "Register product with Windows Installer" option
3. go to "Prerequisites" page and add the setup packages you want to be embedded into your suite installer (the sample embeds two MSI packages)
4. go to "Files and Folders" page and add as temporary file the "ServiceUI.exe" tool and a .ps1 script file that displays a message box
5. go to "Custom Actions" page and add a "Launch EXE with working directory" custom action after "Wizard Dialogs Stage -> Paths Resolution" action group; configure the action to launch "ServiceUI.exe" tool
6. select the above custom action and, while keeping the [SHIFT] button pressed, drag and drop it under "Install Execution Stage -> Paths Resolution" action group; this way the custom action will be shared by both installation stages (UI and install execution)
7. click on "Advanced execution scenarios..." hyperlink and select the "Skip action in Install Execution Stage if executed in Dialogs Stage" option
8. go to "Install Parameters" page and check "Run as administrator" option
9. build and test the suite installer setup
Return to “Sample Projects”
