ALIENQuake
Windows 11 Modern Right-Click for drive
I would like to create Windows 11 Right-Click Menu for drive:
Does the Advanced Installer offer this feature?
Re: Windows 11 Right-Click Menu for drive
Unfortunately not. You can not create context menu for drives.
You can create context menu on Windows 11 only for:
  • File
  • Folder
  • Background
You can check our Windows 11 Context Menu In Advanced Installer article. On this article you will also find a video tutorial.
I have added this improvement on our TODO list. Unfortunately, as for this moment, since you are the only one requesting such feature, it has quite a low priority. However, that can change if more people will request this over the time to come.
Thank you for understanding.
ALIENQuake
I understand, thanks anyway.
BTW: Can you make it so I would be notified if this feature will be investigated etc?
Yes, I already added you to our system. We will notify you on this forum thread if this feature will be implemented.
If you have any other questions, please let us know.
ALIENQuake
It seems that an application called NanaZip succesfully added context menu for a 'drive' in the main Explorer view:
https://github.com/M2Team/NanaZip/pull/313/files
Can you re-evaluate adding this feature now?
If I'm not mistaken, this improvement has been added in version 20.9 of Advanced Installer.
Is this what you would be looking for? If so, please give it a try and let me know how it works.
ALIENQuake
If that's the case, I was not informed by the "system" as was promised by @Liviu. Anyway, bug thanks for implementing this, it will definitely make things more productive.
ALIENQuake
I've checked this and the changelog mentions "Extended classic context menu support for drives".
The feature request was about the Windows 11 modern Right-Click Menu for the drive.
Re: Windows 11 Modern Right-Click for drive
I will forward this to our dev team so they consider adding this feature in a future version of Advanced Installer.
This improvement has been added in version 22.5 of Advanced Installer.
You are always welcome!
Return to “Feature Requests”
