How to add logging functionality to your PowerShell custom actions
Today, we'll be discussing how to make your PowerShell custom actions log their output to a log file.
This involves modifying the custom action itself by adding the functions that will log, either a message or an error.
First of all, we will have to decide the log's location. For this, I will be using the %temp% location.
$logFileLocation = $env:temp + "\CustomActionLog.txt"
Now, if this file does not already exist, we need to create it.
To do this, we can use the "test-path" cmdlet.
if (-not(test-path $logFileLocation)){
new-item -itemtype File -path $logFileLocation
Now that we created the file, we can create our functions as well.
function Log {
    param ([string]$Message)
    $timeStamp = Get-Date -Format "HH:mm:ss.fff"
    $outMessage = $timeStamp + ": " + $Message
    $outMessage | Out-File -FilePath $logFileLocation -Append -Encoding UTF8
function LogError {
	$ErrorMessage = "[Error] " + $Message
    Log($ErrorMessage)
By using the above two functions, you should be able to handle logging the results of your PowerShell custom actions in a log that is separate from the MSI log.
Hope you'll find this useful. :)
Return to “Sample Projects”
