parkerr
I upgraded to AI 21.3.1 and now my exe doesnt work on /quiet
I have upgraded from 21.2.2 to 21.3.1
I have an exe install package which was upgraded from 20.7 to 21.2.2 and was working perfectly, my clients use /quiet for the install with the following command line
TACSInstallationNew50109V2131.exe /i // /quiet /l*v install.log DB_TYPE="SQL" LIC_KEY="873142971045" PRD_NAME="vcs" PRD_SERVER="NSWADCPDB01" TRN_NAME="NODB" TRN_SERVER="NODB" TST_NAME="VCSTest" TST_SERVER="NSWADCPDB01"
It worked for the following for uninstall
When I upgraded to 21.3.1 I can only run the install with the user interface when I try to run the install in quiet mode I get the following log entries
=== Verbose logging started: 17/01/2024 10:22:22 Build type: SHIP UNICODE 5.00.10011.00 Calling process: E:\E\TACSInstallationNew50109V2131.exe ===
MSI (c) (C8:2C) [10:22:22:438]: Note: 1: 2203 2: // 3: -2147286788
MSI (c) (C8:2C) [10:22:22:438]: MsiOpenPackageEx is returning 123.
=== Verbose logging stopped: 17/01/2024 10:22:22 ===
The above is all that is in the log
when I run run the install using the user interface and us /quiet to run the uninstall the uninstall works perfectly.
I have searched for MsiOpenPackageEx is returning 123 and only found one AI entry in the forums for 2013 where thye got the same issue and tried using /exenoui which worked for them, I tried using /exenoui but that didnt work for me.
I urgently need this fixed so if anyone can help that would great, I have a professional licence. I have also attached the 2 different aip files the older one is from version 15.8 because I had to try and create the problem freshly for my testing as opposed to the 20.7 one but the effect is exactly the same.
TACSInstallationNew50109V2131.aip
Upgraded to 21.3.1
(866.21 KiB) Downloaded 393 times
TACSInstallationNew50109.aip
Original 15.8 version
(572.41 KiB) Downloaded 414 times
Re: I upgraded to AI 21.3.1 and now my exe doesnt work on /quiet
Hello Robert and welcome to our forums,
From what I can see, my colleague Dan has answered you over the email.
Please continue the thread with him there.
This has been fixed in version 21.4 of Advanced Installer.
