karthickeyan kannan
Issue with Repair Process - CAB and MSI Files Being Deleted After Installation
During the repair process of my application, I encountered an error message stating, "An installation package cannot be found. Try the installation again using a valid copy of the installation package .msi". This issue arises when attempting to repair the installed application, suggesting that the installer cannot locate the necessary MSI file for the repair process.
I have researched this problem in the Advanced Installer forums and followed the recommended solution to address it. Specifically, I configured the bootstrapper parameters to "Do not delete extracted CAB and MSI files" with the aim of ensuring these critical files remain available for the repair process. Despite this configuration, it appears that the CAB and MSI files are still being deleted after the installation completes, leading to the failure of the repair operation.
How to properly configure my Advanced Installer project to prevent the deletion of CAB and MSI files post-installation. My objective is to ensure a seamless repair process for the application without encountering the aforementioned error.
Re: Issue with Repair Process - CAB and MSI Files Being Deleted After Installation
As I see, my colleague Eusebiu has replied to you over the email.
Please continue the conversation there to avoid duplicate threads.
