h353655
Get PC name as property default
I have a property, where the default value must be the windows PC name. I saw something about using "ComputerName", but that doesn't seem to work.
Edit: I tried using [%COMPUTERNAME], as that supposedly should be the environment variable %COMPUTERNAME%. Alas, it is then set to the computername of the machine who built the installer rather than the name on the machine running the installer. :roll: Not sure in which world that makes sense. Doh....
Re: Get PC name as property default
The value field of properties does not support Formatted data type properties.
If you add the value like this, it won't work:
not correct.png (42.21 KiB) Viewed 8091 times
You need to add a "Set installer property" custom action to set the property to the value of another property. You can add the custom action after or before the Searches action group:
set property.png (81.75 KiB) Viewed 8091 times
