MGS
Button to rebuild just a specific build config
I am missing a button to rebuild just a specific project. Currently, I can only hit the rebuild all button but that's not what I need (as rebuild all will fail for sure for me given that only some of my build configs are able to be built at any time due to the provided files).
Johannes
Re: Button to rebuild just a specific build config
Hello Johannes,
If in your project you are having multiple builds, you can build only one of them as it follows:
Is this perhaps not what you are asking for?
If so, then please give me some more details so I can better assist.
MGS
Hello Catalin,
Catalin wrote: Tue Apr 09, 2024 3:34 pm If in your project you are having multiple builds, you can build only one of them as it follows:
I am already using this option for building a specific build-configuration. But what I am missing is the same thing just for REbuilding a specific build-configuration.
Johannes
Hello Johannes,
Thank you for your followup on this, it is clearer for me now what you want to achieve.
Please note that you can Rebuild only a specific build by going to "Builds" page --> select a build --> press "Rebuild" from the toolbar.
MGS
Thanks for the solution here! I will use that for now.
UX wise I would prefer having the possibility to rebuild a specific project directly to at this Build-menu-button, so that rebuilding is also easily possible:
Johannes
Hello Johannes,
You are always welcome!
Sure thing, I will try and discuss this with our development team to improve the user experience for this option.
Return to “Feature Requests”
