MGS
Collapse all features and their components
Sometimes when I open the .aip project and navigate to the Organization view, all the features and their components are expanded.
Two suggestions:
  • We can press "Collapse All" at a feature, but not at the root node (Product). Would be great if this is supported, otherwise (as multiselect is also not possible) I need to manually click on every feature and hit collapse all. Same for "Expand All".
  • If remembering the current state would always work, it would be fine as is. As currently it sometimes does not remember the collapsed/expand state correctly for me and instead just expands all features and their components at will, I would personally prefer a collapsed state for all features instead as default.
Johannes
Re: Collapse all features and their components
Hello Johannes,
We've included your suggested improvement in our TODO list and aim to implement it in a future Advanced Installer release. We will inform you through this forum thread once it's available.
Thank you for your suggestion.
Hello Johannes,
This improvement has been added in version 22.0 of Advanced Installer, release on August 21st, 2024.
Return to “Feature Requests”
