Chips
Powershell script running on update on first instance
I have an installer that uses multiple instances with the "Generate instances at install time" option. I also have a script that I want to run only during the first installation of an instance.
Currently, my script includes the condition NOT OLDPRODUCTS, which works as expected when upgrading other instances. However, when I upgrade the first installed instance, the script runs, which is not what I intended.
Could you help me understand why this happens and how to prevent the script from running during upgrades of the first instance?
Rafael Marques
Re: Powershell script running on update on first instance
Hello Rafael,
Could you please give me a test-case so I can try and reproduce this on my end as well, because I have tested this and wasn't quite able to do so.
Here's what I've done:
- installed v1
- launch the setup again, install one instance
- change version to 2.0.0
- install the new version -> over both original and the instance
In both cases, the powershell script was not executed when the condition was "NOT OLDPRODUCTS".
