stefan_riediger
"Custom Actions Page" add compact view and expand/collaps all
Dear Advanced Installer Team,
In the version 22.2 the CustomActions View was redesigned using WinUI.
Related to that change, it would be great if you can add
  • a Compact View option like you have for the Left Pane (View->Compact Left Pane).
  • a possibility to Expand All and Collaps All items for example for the UI Sequences or Execute Sequences or each subtree. A keyboard shortcut would also be fine.
Thank you very much in advance.
best regards,
Stefan
Re: "Custom Actions Page" add compact view and expand/collaps all
Hello Stefan,
Thank you very much for your feedback!
I have forwarded it to our dev team.
Return to “Feature Requests”
