AlexMT
Autodesk DWG TrueView 2025 EXE Silent Install Parameters
For those of you needing to deploy Autodesk DWG TrueView 2025 across multiple machines, we list the silent install and uninstall commands which can be executed without user intervention, ensuring a clean and automated install or removal process for EXE installers.
About: Autodesk DWG TrueView is a free DWG viewer that allows you to view, open, edit, and convert .dwg files, the native file format for AutoCAD files.
Application Name: Autodesk DWG TrueView 2025
Version: 2025
Main Application Website URL:
https://www.autodesk.com/products/dwg-trueview/overview
EXE Installer (Silent Install): Setup.exe
/q
EXE Installer (Silent Uninstall): "%ProgramFiles%\Autodesk\AdODIS\V1\Installer.exe"
-i uninstall -q -m C:\ProgramData\Autodesk\ODIS\metadata\{A6C769F8-A5A7-3306-9711-0E6F4C045BA2}\bundleManifest.xml
Return to “Silent Install Command Line”
