Justin
How to install msix in powershell that as a Custom Action
Is it possible to package an MSIX and some APPX dependencies into an MSI and install each package individually during installation using PowerShell in a custom action?
If possible, how should the custom action be configured, and what commands should be used in PowerShell?
Thanks in advanced.
Best Regards,
Justin
Re: How to install msix in powershell that as a Custom Action
Hey Justin,
It is possible to do what you want.
However, please note that for this we have a predefined "Install MSIX" custom action.
However, if you still want to do it with PowerShell, you can use the predefined cmdlets, such as Add-AppxPackage
Justin
Thanks for your prompt reply. It works!!
Best Regards,
Justin
You are always welcome, Justin! :D
